Should be straightforward, but..... | on ElectriciansForums
Discuss Should be straightforward, but..... in the Central Heating Systems area at ElectriciansForums.net
polo1
Glasgow
Changing a faulty Drayton SM1 mechanical programmer with a Siemens RWB 1007 programmer (both single channel) serving a Ferroli DOMIcompact F24D combi boiler.
System appears to wired - mains, programmer, thermostat, boiler. The original back plate serving the Drayton had a link between L & 1, with the thermostat feed in 3. Keeping this arrangement with the Siemens, the thermostat (and hence the boiler) has a permanent feed even when the programmer is switched off.
Tried various permutations, but only ever get perm feed to thermostat with the programmer off, or no power to thermostat, irrespective of the setting of the Siemens programmer.
Confused!
Confused!
Perm live to 2 and switch live to boiler from 4. If you look at the manual it says if using 230V switching then link live to 2. 1 and 3 is used for the permanent live to the boiler and is normally closed so it disconnects the boiler when the service interval timer kicks in and opens the contact between 1 and 3. This way the boiler can't be used until it's serviced and reset.
[ElectriciansForums.net] Should be straightforward, but.....
Thanks all. After a bit more head scratching, I discovered that one of the programmer pins was not making proper contact with the backplate connection ( serves me right for not replacing the backplate!).
Now sorted & working.
Reply to Should be straightforward, but..... in the Central Heating Systems area at ElectriciansForums.net
