Philatc
Hello everyone, I recently added an EV charger to my electrical panel. Upon closer examination I noticed the common/ground bus bar wires are corroded?? As far as I know there have been no chemicals in or around the garage or breaker panel. The house is only two years old. I also have lights that will flicker from time to time. I installed a Surge Protection device which hasn't seemed to make a difference. The common main service bar screw is tight. All the screws on the bus bars are tight as well. I'm not sure if this is just normal corrosion for my area or if this is something I should be concerned with. I've attached some pictures. Thank you all in advance.
