Should I change from Domestic to Commercial | on ElectriciansForums
Discuss Should I change from Domestic to Commercial in the Domestic Electrician Forum area at ElectriciansForums.net
Sparky2108
I'm currently working on new build houses across Essex as a second year apprentice, although it can be "hard graft" it's not that bad and I don't hate it. However I'm getting to the stage now where I can do pretty much everything involved with wiring new build houses and I feel I should consider moving on to commercial/industrial to better myself and my career in the long term as an electrician.
The main thing I would really appreciate advice on is should I change companies? and advice on the transition from Domestic to commercial/industrial.
Cheers
I would definitely recommend getting some real commercial and industrial experience. There is so much more to being an electrician than wiring new builds. However changing companies is a big step and not sure if that would be a wise move. Depends on circumstances.
Give me commercial any day, if you chose this route you will never want to do housebashing again.
He is only 2 years in Westie, IMO he is lucky that he is getting experience in the industry in today's climate, don't walk before you can crawl.! Having said that in my day Electrical work was just that across the board.
Can't disagree with you there.
There is no harm in looking around to see if you can find another company where you could continue your apprenticeship in other areas of the industry.
If you can find a suitable job to move to then I would advise you to do it, gaining more varied experience whilst you are still an apprentice will open up more opportunities to you in the future.
2 years in is quite long enough to get a working knowledge of the domestic sector, I think it's safe to say he should be able to crawl by now. If he can continue his apprenticeship somewhere else where he learns about the rest of the industry then I think that it isn't his best option.
You say that in your day electrical work was just that across the board, but appear to be ad coating this guy restricting himself to just domestic work?
If you don't move your just end up a cheap form of labor, I know guys who are in the same situation on the cards and the cis route.
New build work runs like a factory production line, everyone as a role to play and that's how it stays.
The lads think they are going to become electricians and work for themselves one day, ie set up business.
You need to work towards a JIB Gold Card then you should always be able to earn a living.
I'm in
I'm in this exact boat need some commercial experience don't care about domestic work I been doing it for ages I just need to complete NVQ my company will sub me out eventually but they don't like to move fast it's like they don't want me having a gold card stuck on labourers card
Reply to Should I change from Domestic to Commercial in the Domestic Electrician Forum area at ElectriciansForums.net
T
Signs of Growth in Q2, Reports CPA - From TTA Signs of Growth in Q2, Reports CPA - From TTA The health of the construction industry improved...
The Tile Association
T
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
