Should we use copper blade crimps? | on ElectriciansForums
Discuss Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
london
hello guys
I quite often find that when terminating 25mm tails into a 100a fuse board isolator you do not get the 25mm tails to squash nicely by the main switch thermals like you would 16mm tails, should be be using copper blade terminals instead to ensure a better connection?
hello guys
Explain please, a picture of what you are suggesting will help.
Thanks Westy
hello guys
From Westies info then no unless the terminals are designed for flat cables imo
You shouldn't have problems terminating 25mm tails into a switch. If you are then you are doing something wrong.
You need to use your hands and form the cable correctly so it simply drops into place without putting strain on the switch and then tighten.
Reply to Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
