Shower cable selection (Regs) | on ElectriciansForums
Discuss Shower cable selection (Regs) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
Nasa_steve
Hi guys
I've been working on a site and I've had a problem with the site agent and his QS both are convinced that in the regs there is a rule suggesting that ALL showers MUST be wired in 10mm minimum. Whilst I appreciate that it is generally accepted that 10mm is a rule of thumb . I also was only aware of the reg relating to sufficient current carrying capacity and not a reg specifying what size cable to use.
I've checked my current on site guide and I can't find a reg that specifies 10mm t&e minimum for ALL showers please tell me in not loosing the plot
Cheers
Nasa
i agree with you. 6mm is adequate up to 9.5kw. the only reason 10mm was specified in the 16th fo over 8kw was volt drop.
Reply to Shower cable selection (Regs) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
