W
wingnot71
Hi all, replacing an old shower and I need to extend the cable slightly. The cable(10mm) runs through the loft void and down a stud wall to the isolaing switch. Can I add a junction box in the loft and run the new length down from there or do I have to run it back to the isolating switch as to do this the cost of cable would double. If I can use a junction box would a 30amp box be ok, The new shower is 9.5kw.
Many thanks...
Many thanks...
