B
bathroomboy
Installing shower cu with 16m/m tails and 10m/m t&e to shower, I will need to put cables through the top of the shower cu case, how do I comply with ip regs, i.e not able to pass anything above 1m/m into the case, can I use grommets on the cables or is there a better method.
Tails far too stiff to feed from the bottom. Maybe if I mount it on batons I could feed the cables through the back of the casing.
