Guest viewing limit reached
O
One_of_them
hey lads
when you guys fit showers or run the cable, do you put sealant round where the cable and/or pipe comes through the tiles?
any pics would be great :)
you just go for the slap it on thick approach or are you a bit artistic?
do you find you gotta wait for it to set before making any attempt to bend the cable (depending on entry approach) to ensure it seals correctly?
I would mate. Dont forget you have a duty to ensure the integrity of the building structure and i would say that includes internal walls (be they solid or plasterboard/aquapanel) so i would be sealing it to protect against water ingress (the same as you would for an electrical enclosure)..........
Shower entries
Australia
One_of_them,
GLENNSPARK,
