Shower extractor fan wall mounted | on ElectriciansForums
Discuss Shower extractor fan wall mounted in the Australia area at ElectriciansForums.net
Can a wall mounted shower extractor fan - 12v - IP44 be replaced like for like.
Existing broken but not keen to fit or sure if wall mounted alound in shower cubicle?
Electrical equipment installed within zone 1 must be at least IPX4. 701.512.2
Showers & shower pumps, extractor fans, electric towel rails, whirlpool units, water heaters, lights and SELV or PELV equipment not exceeding 25v ac or 60v dc are permitted in zone 1. All equipment must be fixed and permanently connected. The SELV or PELV transformer and isolator must be outside zones 0, 1 & 2. 701.55
All circuits in a bath or shower room must be protected by a 30ma RCD. p6, 701.411.3.3
Yes as long as you comply with the above
Reply to Shower extractor fan wall mounted in the Australia area at ElectriciansForums.net
Elkay 2235A-1 Energysense White 3 Wire Touch Timer 16A 240V. This is a touch timer (you don't need that bit) which also can be activated by a...
Maybe you could use an in-line mixed flow fan which will be quieter and more efficient than an axial. This one is an S&P which is a good make and...
