Shower extractor fan wiring | on ElectriciansForums
Discuss Shower extractor fan wiring in the DIY Electrical Advice area at ElectriciansForums.net
R
Richie62
Hi all,
i would like to know which is the best way or ONLY way i can install a overhead shower extraction unit with a single low voltage lamp encased in. The shower is a 10.5kw unit with a 10mm feed and a 40amp RCD, the pullcord switch is double poled. The bathroom has a window for natural light and ventilation and has 4 low voltage lamps wired on the house lighting main. At the moment I am carrying out other works on the house which include having a couple of new ring mains and a new Consumer Unit (which a Qualified Electrician will be installing :smile:) the consumer unit is 30+m from the bathroom. I would like the extractor/light to be active when only the shower is being used and independent of the bathroom lights as dont need the main lights to be on during daylight. Can I wire it up to the pullcord switch of the shower isolation (knowing its a 40amp RCD and possible putting in an inline fuse) so the extraction/light come on with the shower or do I have to put a separate circuit and switch in :sad:.
All help/advice gratefully received
Thanks, Rich
i'd have the fan independent of both lights and shower. then you can control whenever you want it. as work in a bathroom is notifiable under part p, ask your electrician's advice.
Thanks Telectrix, I was affraid that would happen, I just didnt want another pull switch in the bathroom which would make it 3, the kids are bad enough for turnig things off as it is lol.
Reply to Shower extractor fan wiring in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
Which begs the question, where does the second brown wire come from?
