Shower Fitting - Silly questions Coming Up | on ElectriciansForums
Discuss Shower Fitting - Silly questions Coming Up in the Australia area at ElectriciansForums.net
Wiltshire
as i am still learning i will put a lot of silly / obvious questions up, Right, in my house i want a new shower installed. before we moved in the wiring for the shower, 10mm wired from ccu to pull switch in bathroom has already been installed, there is also a riser ready for the water supply, my question is if i install a shower and wire from the switch is this notifiable?
Rob
Reply to Shower Fitting - Silly questions Coming Up in the Australia area at ElectriciansForums.net
I
No water in shower head, pressure/flow problem Dear Professionals, could you please advise. I have standard mixer tap in my bath (its about 15...
IrinaPri
I
Better off with the click prw213 as it has twin screw termination.
