Shower Isolator in a Bathroom airing cupboard | on ElectriciansForums
Discuss Shower Isolator in a Bathroom airing cupboard in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Wales
Hi All!:)
Hope you can help with this PIR question!
What code would you give a shower isolator in a bathroom airing cupboard?
as far as i know, as long as it is accessible, no code, no problem. as long as there is a door on the cupboard. not ideal, but nor is it best practice.
Thanks telectrix and kmcgold for replies!
When You say it's not ideal nor is it good practice and taking on board what Kmcgold has said.
With the door open it's within zone 2. Would it not warrant a code?
but then you could open the bathroom door ( small bathroom) and then the landing could be in zone 2 by the same argument. the fact that the cupboard has a door puts it outside the bathreoom IMO. some may disagree.
if it was a walk in cupboard may be but
it is a cupboard inside a bathroom not a different room imo
will you be standing in a zone when operating the switch?
Me im agreeing with telextric no code seperated by a door , so if you take reg 701.32.1 into account then there shouldnt be a problem, reg states horizontal or inclined ceilings walls with or without doors floors and fixed partiones may be taken into account where these effectivly limit the extent of locationjs containing a bath or shower as well as their zones
you stand in the shower to turn it on. the thingy in the cupboard is to isolate, not operate.
What zone is the inside of a cupboard? ................... As said before if the door is not locked and the switch is accessible there is no problem that I can see. How many fan isolation switches are in bathroom cupboards?
Reply to Shower Isolator in a Bathroom airing cupboard in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
At some point, all sewage pumps will fail, or need extensive maintenance. I make it quite clear that I'm not interested in either.
There is also the ongoing problems if this is a gendered changing room.... For example, 2 or 3 burly male soldiers (you said it was an officers...
