Shower light on when shower not on? | on ElectriciansForums
Discuss Shower light on when shower not on? in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi, I've noticed my shower power light is on when the shower isn't in use, it's no-where near as bright, quite dim but flickering. After this shower has been used it doesn't happen. I have a couple of ideas, but would appreciate thoughts.
Thanks.
It is quite possible that you have water leaking inside the shower and providing enough of a path across the switch contacts to allow the light to illuminate slightly. Well worth isolating the shower and removing the front cover to see if it is wet inside. (and if so finding the source of the leak and fixing it)
Tel sorry fella but i've had to delete that reply because while I know it was said in jest it is in the open forum and it was asked by a Trainee( don't know if you noticed that ) But I know you will understand why It had to go.
no problem, mate. ( i'll get you later. :20: ).
Thats what I was assuming, seeing as it is like it before the shower is used but after use it had presumably made enough heat to evaporate the water.
Just looked at it, there is condensation on one of the micro-switches that switches between the different elements.
An IR test of that micro-switch was 3 Mohm, the other three micro-switches were all 13+Mohm.
I'll leave it until tonight and check the resistance again.
Not sure why the condensation has suddenly started happening though, there's no other water inside, no water marks or anything near the switch. It's fairly near the heating cylinder though.
It may be possible that the cold supply pipe is condensing either inside or outside the shower. In the case of the outside it may run in from an unsealed pipe entry , or just condensing internally because of temperature differential on the cold pipe.
Reply to Shower light on when shower not on? in the UK Electrical Forum area at ElectriciansForums.net
Oh definitely, the amount of tails that I come across in consumer units barely nipped up is staggering, I always tighten them, wait a minute, give...
Better off with the click prw213 as it has twin screw termination.
