A
Discuss shower not working! in the Talk Electrician area at ElectriciansForums.net
I hope theres some slack above to pull down!!!!
Quite the salesman there Tel.get teenage daughters out of the bathroom when you need a dump.
probably some slack on them terminations that caused it..I hope theres some slack above to pull down!!!!
...its an item that is too easy to be fitted badly, no matter how much time you take and how tight you try and get the connections you never know whats happened when you push it back into the ceiling
why is it always the neutral though? that is a burning question.
Well it's something that probably should be added to the current Ring v Radial thread, as it occurs to me that it’s usually radial circuits, shower and cooker radials in particular, where one or more of the N connections burn-out, this is probably due to the standard test method not requiring Rn to be measured![FONT=&] At least the standard tests for RFC checks Rn; which is more than can be said for the standard tests on radials.[/FONT]
Reply to shower not working! in the Talk Electrician area at ElectriciansForums.net
