shower on 6mm for future | on ElectriciansForums
Discuss shower on 6mm for future in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
i was asked to pull in a shower cable and leave in wall for future as customer has been roked into other work, so makes sense now as they have the room.
9.5kw shower on 6mm is fine according to osg upto 43m on ref method c. i only have an 8m run and is in rafters with kingspan but kingspan wont be touching it. it has 150mm rafter with only 100mm kingspan..
so at least a 50mm gap around cable
i said its dead on for 8.5kw shower but i do think 9,5 will be fine aswell.
thoughts
well righard there is only a 2.5mm in the 6mm t&E
If the cable is not in or under any insulation then 6mm should be OK for 9.5kW.
I get 3.88 with the adiabatic equation (for a 40A BS60898).
- - - Updated - - -
200 x 200 for the 40A breaker
How do you get that without knowing the PFC of the circuit? :bucktooth:
Richard has used the Ia value for the breaker (200A) which would cause the breaker to operate in 0.1secs.
S = √(I² x t) ÷ k
S = √(200² x 0.1) ÷ 115 = 0.55
However the correct value to use is the actual fault current that could flow in the event of a fault (Ipf = Uo ÷ Zs) which could be a lot higher if the Zs is low enough.
Reply to shower on 6mm for future in the UK Electrical Forum area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
