Shower on Ceiling Light Flickers - advice needed please | Page 7 | on ElectriciansForums
Discuss Shower on Ceiling Light Flickers - advice needed please in the UK Electrical Forum area at ElectriciansForums.net
UK
Hello, I am not an electrician. I don't normally post on forums but I'm at breaking point with this situation and require some advice please.
Our new shower was installed earlier this year. Since it was installed when you press the new shower on the ceiling light in the bathroom flickers (strobe like) as does the ceiling lights on the landing and small bedroom (all on the right side of the house.)
No other lights flicker when the shower is on anywhere in the house and the bathroom light doesn't flicker at any other time when it is on (only when the shower is on.) We have changed the light bulb in bathroom and it's still flickering only when the shower is on.
When the shower is turned off the flickering stops immediately, however, the shower is on one consumer board and all ceiling lights are on a separate consumer board. We have been told the cable is correct for the connection of the shower.
With the old shower there was only a small dip in the ceiling light when it was turned on similar to when we put on our hoover and our downstairs table lamp dips in light once. We have been told this dip (or blink) of light is normal due to the load it uses.
We use a 25watt incandescent bulb in the bathroom. We use these bulbs as a family member has seizures to LED and fluorescent lights and can't use any other bulbs. We are aware they are no longer available to buy.
I've had 3 electricians out and also the local electric board to test equipment and they are sending us round in circles (electrician says everything is working normal and it's a supply issue and supply says it's a electricians issue as there are no supply faults.) Our meter doesn't reflect any issues so the electric supplier won't send any one out to look at their equipment other than the replace the existing meter.
We need to have a new hob and oven installed and the electrician has said we can't do that until we find what is causing the flickering issue, however, the electrician has said he cannot find the issue even though the flickering is visible and he has seen it. He has told us to keep a diary of when the flickering occurs (but it is only when the shower is turned on that it happens.)
The shower company cannot help us with this as they are only for installing and repairs even though we have told them it started when the new shower was installed.
Can anyone advise what I need to be either doing or asking because I'm at a loss on what to do and just want to get the house back to our normality again. I am not going to do any work on this as I am not an electrician.
Many thanks for your time with my query.
Reply to Shower on Ceiling Light Flickers - advice needed please in the UK Electrical Forum area at ElectriciansForums.net
Neutral and live
J
Electrician Electrical shower problems Electrical shower problems I have installed a new shower and when the dial is turned to economy the light...
Johnales
J
