P
peteelecs
I need some help please my daughters shower when swithed on the water is only warm not hot adjusting themostat makes no difference does this mean its the heating element or should I be looking at something else?
Discuss Shower only warm in the Talk Electrician area at ElectriciansForums.net
Might just be that the incoming water is so cold it isn't heating the water enough, quite normal at this time of year,especially on older showers, what size is the shower?
If it is the bog standard type it could be one off the elements has gone as when you put it on the low setting you normally have the 2 elements in series, on the medium setting one element on and on the high setting both elements are on.
Is that in parallel Ian?
Thought that was obvious if they are in series in low, whoops forgot with some off the questions being asked on the forum lately should not assume should I
I did say with older showers, but without any info just assuming?Quite normal?
Reply to Shower only warm in the Talk Electrician area at ElectriciansForums.net
