Shower or Basin?xxxxxxx | Page 3 | on ElectriciansForums
Discuss Shower or Basin?xxxxxxx in the UK Electrical Forum area at ElectriciansForums.net
Zdb
Nearly Esteemed
UK
So I've been doing some work in a building and the fuseboard is located in a room which has been converted to a "multifaith room". It's basically a prayer room for Muslims as it's been kitted out with the facility to wash their feet and also a hand dryer mounted low level to then their dry feet.
I couldn't help but notice the proximity of the water outlet to the hand dryer and also the distribution boards.
Any thoughts?
[ElectriciansForums.net] Shower or Basin?xxxxxxx
I mean... If you look up in the dictionary shower that basin hose, technically isnt a shower.
Im writing in this thread with common sense and a bit tongue in cheek, as if thats me id be on the blower to the NIC.
Me too..
Not #MeToo, i wasn't touched in the bottom by a film director.
Technically if i wanted to from my shower i could probably spray the landing socket with the right water trajectory.
if you can pi$$ that far, ever considered being a firefighter?
May be it just needs a shorter hose on the shower head and turn the pressure of the water down, is this not the same as a hair dressers where they have shower heads over the basins? I would not say its a special location but the accessories , hand drier and fuse board may not be suitable for the environment they are in ?
My biggest worry is that it is specifically for the cleaning of feet, and I'm pretty sure that wet bare feet and the improved connection to earth via said wet feet is the main reason for more stringent requirements in bath and shower rooms. You can easily have wet hands in a kitchen or toilet, but these are not special locations.
Interesting scenario, not one I've come across before, but my gut instinct is that some improvement needs to be made here. How you apply the regs to it is more difficult, but I think it would be appropriate to classify this as a room containing a shower, since it is specifically intended for use as a body wash, not a flexible dishwashing device.
I doubt if anyone checked if it was safe or compliant with regulations before installing the footbath and dryer. I would not want them in the same room as those large consumer units steam will fill the room. Install a shorter hose on the shower head say half length, that would help. Seems to be an enclosed room where is the extractor fan to comply with building regs?not for me.
Reply to Shower or Basin?xxxxxxx in the UK Electrical Forum area at ElectriciansForums.net
M
Intermittent bad smell Hi I have an intermittent bad smell that's really hard to pin down, I was wondering if I could get your thoughts on it...
MatthewG
M
