Discuss Shower overheating. in the UK Electrical Forum area at ElectriciansForums.net
I'll see if he wants to fix or repair, if he says repair ill see if I can get some block from manufactor, good advice cheers.Ensure that the cable from within the shower is not corroded from the heat, otherwise when you replace the terminal block you will still get a high-resistance connection. Check that the plastic of the housing has not been compromised too. It looks like one of the retaining clips that holds the terminal block is damaged. If the '-2021' on the back is the date, it ought to be worth the effort of repairing.
OK so just use 60amp connecter then, got some lying around like.block is block.i'dget a ceramic one instead of softy softy polysh*t..
block is block
Reply to Shower overheating. in the UK Electrical Forum area at ElectriciansForums.net
