Shower pull switch opperating on load | Page 2 | on ElectriciansForums
Discuss Shower pull switch opperating on load in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
A friend of a Friend asked me to go and look at a Shower that didn't work, sure enough it didn't, I took the switch off, and the connections were, to say the least a bit iffy, cores cut out, tried my best to find out who did it and after some detective work he came clean and admitted it was him, changed the switch as a safeguard, all OK until this morning, shower packed up, got there did some checks, found the switch was faulty, he said this was the second time the switch failed, he was leaving the shower switched on at the shower itself but switching it on and off via the pull cord, I reckon switching the load via the pull cord damaged the switch, any thoughts?
I don't know why people insist of using the pull cord, when a shower has a perfectly serviceable on off switch. Same people don't keep switching their electric oven on & off at the wall :mad:
So would you install a Shower / Cooker without an Isolation switch then? I only ask because I had my Bathroom refurbished (only because I am old and can't do it myself) and the chaps doing the work told me I didn't need an isolation switch for my shower.
Nope needs an isolator, but they are not really functional switches IMO. There as an isolator for maintenance or safety. Bet if the shower had a digital clock on it, they wouldn't be using the pull cord all that often.
PS 'Old' more like elder statesman :)
You cheeky T--t:D:eek::oops:o_O
I wanted to like Post 17 but the option has gone! Where's the like button? Has it gone the same way as the 'thanks' button or is it just me that can't see it ?!?
Dazburnsout.
Reply to Shower pull switch opperating on load in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Ah OK, that makes sense. Thank you Avo.
