been asked to price for a new shower supplied and plumed new supply how much would you charge i figured about 270 is that too low shower costs 138.
Discuss shower quotation in the Talk Electrician area at ElectriciansForums.net
Going on the info I would quote 350. Gives you a profit of 212 minus cable and plumbing costs.
I would always install a 10.0mm T+E Cable as standard practice for shower installs even though this is were someone could beat your quote, I would also advise that you would then be able to upgrade to a more powerful shower later on.
I'd install whatever suited the connected load and overcurrent protective device, win the work then on to the next job, why risk losing the work on the basis of a future upgrade?
In this case for such a small run, the difference is negligible but it can soon mount up.
Reply to shower quotation in the Talk Electrician area at ElectriciansForums.net
