P
pdlaw
Hi All
I've read quite a few posts and wonder if I can ask some advise please?.
My father only has a bath in his house and being elderly has trouble getting out of it when he's sat down..
So I've purchased a an electric shower for him. 10.5kw.
The Consumer Unit in the house is a Proteus Centaur 80/2/30 which has a master cut off switch described as an ELCB. There is a button next to it which trips it, and I use this for diabling the electricity when changing bulbs etc. To get the electrcity back again you need to turn the switch, which is a little like a dial, clockwise.
The shower needs an RCD (as you'll all know better than I do!)...which the manuals says can be part of the consumer unit or seperate.
I plan to wire the shower to a pull cord not accessible while taking a shower itself, then route the cable to the main CU downstairs.
At this point I would call in an electrican to fit the wiring to the CU with a 45amp MCB.
My question relates to the ELCB. I have read that current operated ELCBs are the same as an RCD, whereas the voltage ones are not. I wonder if anyone knows if a Centaur 80/2/30 does the same job as the RCD?
The reason for asking now is because I don't want the expense of calling out an electricion if we can't afford a new consumer unit or any extras. I'll have to forgo the shower for him until I can afford the extras.
In a nutsell, would my setup be safe with what I have?
All advice gratefully recieved.
Phil
Phil
