I
irishsailor
Guys
I have been asked by a friend to fit a shower. He currently has 6mm but as it is 9.5kw shower will need to fit a 10mm.
However he has an ols Square D board and does not reall want to upgrade board. I was thinking of installing a small oneway Shower RCD.
I intend to run new tails from the existing meter block to the RCD unit. I was thinking of using 16mm tails is this acceptable??
Also will upgrade Gas & Water Bonds.
If I am only touching this individual circuit am I responsible for RCD protecting the lighting etc in bathroom
Chris
Chris
