Shower supply | on ElectriciansForums
Discuss Shower supply in the Australia area at ElectriciansForums.net
Hello peeps just a quicky,
I installed a shower circuit this morning and changed the dis board. It was a 9.5kw shower wired in 10mm and on a 50A Type B breaker rcd protected. But when the shower operates there is a loud buzzing from the board, I checked for tightness in case it was arcking and everything was ok. Is the buzzing normal or not? Cheers
Sent from my iPhone using Tapatalk
Heya mate
There shouldnt be any buzzing noise lol is it a cheap make of mcb/cu? could just be a faulty mcb. If all your test results were fine then i shouldnt worry unless its so loud you can hear it over the tv :D
Hope this helps
Shane.:cool:
Phase2Phase said:
Heya mate
Hope this helps
Shane.:cool:
Yea my thoughts were faulty mcb, didn't test it today coz it was for a mate and had to shoot off. Il change the breaker on Monday I'm sure it'll be fine til then. And yes it was a cheap basics board from denmans lol
Yea like the patress box's that are good if u like the ones that snap in half as soon as u tighten it up the tiniest bit too much lol the boards are pretty decent tho, QFS I think they are
Reply to Shower supply in the Australia area at ElectriciansForums.net
