G
gowerjack
Old Triton shower tripped RCD so I replaced today with new Triton shower.
Still trips RCD ( maybe old one wasnt faulty?)
8.5KW on Wylex B40 mcb, 6mm 6242yh ( but only approx 5mtr run ).
RCD & MCB hold untill I switch on at ceiling switch,then trips RCD but not MCB ( so earth fault not overcurrent).
Linked out switch same result,changed switch same result.
Cable is surface & shows no sign of damage.
Am not prof sparkie so no test equipment.
Do I need to replace the cable from the switch to the shower?
Can anyone advise?
Thanks in advance
Steve
Can anyone advise?
Thanks in advance
Steve
