Showerforce 2000 - anybody replaced the mixer seals? plumbing advice | on ElectriciansForums
Discuss Showerforce 2000 - anybody replaced the mixer seals? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Showerforce 2000 - anybody replaced the mixer seals? Hi
This relates to an earlier thread
I have the above old shower which leaks ; you can no longer get the Showerforce Service kit to replace the seals
so I wonder if anyone has done this job and whether suitable seals can be sourced from somewhere?
This is what the mixer seals look like ; they have worn over time allowing a leak
[ElectriciansForums.net] Showerforce 2000 - anybody replaced the mixer seals? plumbing advice
I really want to keep this shower going if I can so if a fix is possible I would be very grateful
thanks
Showerforce 2000 - anybody replaced the mixer seals? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Showerforce 2000 - anybody replaced the mixer seals? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
B
Mixer tap ring sheared during seal replacement - how remove In serious trouble here, was going to replace seals around base of mixer tap spout as...
Barnjet
B
E
Mixer Tap Cartridge change advise. Hi Our kitchen mixer tap is leaking around the bottom. Unsure where the leak is coming from but suspect/hope a...
Eejay
E
