Shutting the building down | on ElectriciansForums
Discuss Shutting the building down in the Commercial Electrical Advice area at ElectriciansForums.net
bartkusal
London
Hi all you smart folks, wonder if you can help me.
I am from London worked on job in Southend last 3 days, commercial premises, 400A 3ph.
Had to connect the new 63A 3ph fused isolator to main bus bar chamber, which required to shut the main fused switch to the building, which is broken and not shutting down and needs replacing. My manager spoke to many contacts apparently and it came back that it will take 2 weeks to get someone in to isolate the main head.
Just wonder if there is any better way to approach this issue and get it done ASAP, as client has an event going on and wants it all completed by Thursday next week.
Thanks, in advance
If there is a dangerous situation you need to isolate the supply. Without knowing more I would assume your situation isn't immediately dangerous, but under fault conditions could be dangerous if you are unable to isolate the supply. Surely if your manager explained this to the DNO they would respond quickly. I'm presuming its your local DNO that he has contacted. If he lays it on thick about safety I think you may find they respond quicker.
Correct, its not immediately dangerous but it is in many other ways. I did tell my manager to go the safety route, but I think he is a bit soft and failed.
Thanks.
This site changed a lot since last time I been here, where the thanks button gone???
Seems you are the guy who would do anything to get power going... :)
No chance I am considering this option with building 40 years old and spaghetti junction in bus bar chamber.
Still thanks for your help...
Thanks.
Been a while since I was on too. I haven't figured out the 14 ish responses yet myself. It's obvious what the thumbs up or thumbs down is, the rest I will discover in time.
Theres always a way . Luckily you have a boss who you can pass the problem to :D
Reply to Shutting the building down in the Commercial Electrical Advice area at ElectriciansForums.net
