Siemens cooker tripping | on ElectriciansForums
Discuss Siemens cooker tripping in the Australia area at ElectriciansForums.net
Q
quimono
My Siemens, under-the-work-top cooker, keeps tripping the electrics once it has been heated up for cooking and then turned off after use. Its driving me mad. any one know why this is happening? Kim
There may be an insulation resistance problem,most likely with the oven itself. Try isolating with the wall switch,if it no longer trips that would confirm the oven is the likely culprit. That said RCD's can be misleading,a test by a competant electrician is advisable....if you post your location someone on here may help.
Reply to Siemens cooker tripping in the Australia area at ElectriciansForums.net
The crimps that fit onto the end of elements can be very close to the metal body of the oven when pushed back in… check they’re not bent, and...
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
