Siemens dimmers r/c etc, | on ElectriciansForums
Discuss Siemens dimmers r/c etc, in the Electrical Tools and Products area at ElectriciansForums.net
K
Kiers1970
just seen these on the orange shed site... they look great TBH, anyone had a dabble? Lutronish in design.
Just fitted some today. Make sure you get slave switches to go with them if you are doing 2 way switching. Also 2 and 3 gang switches are interlinked so you can't mix slave and master switches. To be quite honest they are a very expensive for what they are.
Reply to Siemens dimmers r/c etc, in the Electrical Tools and Products area at ElectriciansForums.net
The locations are defined by Groups relative to the procedures which are carried out.
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
