Siemens rwb29si central heating timer | on ElectriciansForums
Discuss Siemens rwb29si central heating timer in the UK Electrical Forum area at ElectriciansForums.net
I
ICE
Hiya all you good looking sparks,
I have a Siemens rwb29si central heating timer and it is stating "service due" and has stopped my heating from working, how the f#€¥ do I reset it?
thanks
- - - Updated - - -
I have googled it but with no luck
You need a code, which would have been programmed in when it was installed/last serviced by the fitter.
No idea about Siemens, but on the Honeywells with that feature, there is no way of resetting the PIN number, if you've lost the number, it's a new programmer.
As yours is carrying on working, it shouldnt be a problem, they can be set to turn off, and not come back on again, if that happens, you are stuffed, so new programmer again.
Reply to Siemens rwb29si central heating timer in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
