R
Rockington
Hi need to wire up a couple of signs at a doctors surgery , one at back one at front . Customer only wants them on till around 8pm so decided to put each one on a digital timer and photocell . Went to install today and the green brook timers don't work with a photocell . Anyone know of any specific digital timers which will work with a photocell as all the ones I've checked are the same
cheer sin advance
Ho welcome to the forum.
You say you are an apprentice, if you are actively in course at the moment it might interest you to apply for access to the trainee forum which will be more suited to your level and experience, its just a suggestion not a requirement :)
In reply, what do you mean they are not compatible with the sensor?
Do you require a timeclock with vaults free contacts - you feed the sensor with permanent power then run the switch wire through the volts free contacts to the fittings.
Can you post a wiring plan of your set-up?
OK Photo Cell post 1 Red wine again sorry for the error
In my experience Doctors can be a preverbial pain in the butt about these signs been on too early so his options are to fit an expensive seasonal timeclock x2 (as he suggests he has wired) or 2 cheap time clocks with independent photocells...I usually find quotes are won with the cheaper option but just as reliable.
Edit - or as Murdoch has linked to.. first time I seen these units myself :wacko:
Fitted loads of these, they are excellent.
Hi darkwood , am apprentice trained but at 43 definitely not an apprentice!! . Price isn't the issue , just want it right but the digital timers won't work through a photocell. Murdoch , I saw these earlier , when I was looking for alternatives but noticed they can only be set for periods of time after dusk . If this is the case in summer the sign would come on from say 10 to 12 midnight !!
They only want it on when it is dark but going off at around 8 or 9 .
Can you post a wiring plan... I cannot understand why you cannot use a standard timeclock with volts free contact to switch a photocell switch wire?
Why don't the digital timers work?
A single channel CH programmer like a Drayton lp711 will give you a volt free output that will work.
Of price really is not an issue then stick a Sangamo solar timeswitch in there!
The instructions say can't be used on dimmers or LED lighting , so rang technical dept about photocells , and said wont work .
can use a standard time clock , but as they are situated in offices wanted something smarter . Thought there must be something out there made for the job that someone had used before !!
I suggest you read post #6
Can't the timer output simply feed the photo cell with the return powering the lit signs ? Then even if the timer was set early the lights wouldn't work until dusk and the timer could remove the supply to the photo cell/lights at 8pm.
Not the best design to energise and de-energise the dusk/dawn sensor with a timer as it will bring the lights on regardless when energised until the electronics have settled and monitored light level, you need permanent power to sensor and interupt the switch with timer.
Yeah I did consider that but with an electronic PEC it would only switch on if energised in daylight for a few seconds before cutting off although I agree it's not a perfect solution. :smile:
Just fit the Steinel Product - on at dusk, off at a constant time, no fiddling with a timer!
The instructions aren't clear on that. Can you actually set it to switch off at a specific time?
Hum.. not to an actual hour or minute but its a constant time, you just need to fine tune the adjustment! Thats the only downside to the product but never had a complaint as people like the ability for it to come one when it gets dark and they never have to adjust it!
It keeps track of the local astronomical 'midnight' by monitoring sunrise and sunset over a period of a few days. You can bias the turn off time by a few hours either side of midnight, but not with any precision. It doesn't know about summer time.
You can also tell it to come on for a while until it gets light in the early mornings when the nights are long.
You might need a second visit to tweak the timing, but once it's set, it's a pretty good controller for 'welcome home' lights where you don't want the lights turning on and off on a pir. I have one controlling a fancy wall light which backlights the house number.
Adaptable box under or next to or above fuse board, time clock and contactor mounted on dinrail in said box. From time clock into A1 and A2 on contactor, lights feed in to1+3 feed out in 2+ 4 to photocell, photocell to lights, all fed from same MCB.
time clock energises contactor and energises circuit, if dark photocell turns on lights and at 8 pm time clock de-energises contactor and cuts lights off
Signage lighting
Thread Tags
Tags Tags
lighting
Rockington,
jase,
