Silavent mayfair 202b bathroom fan | on ElectriciansForums
Discuss Silavent mayfair 202b bathroom fan in the Australia area at ElectriciansForums.net
P
Philepo
Hi, just wondering if any one could shed any light on this for me and back up what I already think. If this fan is wired up from
The lights via a SL and N setup. with no permanent feed.
If the SL was connected into the live or SL terminal on the fan would it cause the fan to malfunction. Thanks.
I've been told when this fan has been connected up, it's been connect SL - live terminal
On fan and n - natural. Iv been told the fan worked fine, coming on with the lights and going off with the lights, as switched. Should ther be any reason for this to Damage the fans motor connected the way.
Personally I don't think so! I can't see how it would effect the motor.
Reply to Silavent mayfair 202b bathroom fan in the Australia area at ElectriciansForums.net
I have posted this years ago, it is the way I wire fans which gives the fusing required by a lot of manufacturers and the isolation required...
It would normally be the outer terminals where the flex of the pendant drop connect.
