Silent Running Toilet eluding capture I have three toilets in the house. Two have been "silent running" for a while now (constant trickle of water leaking from the cistern into the bowl).
They are identical Ideal Standard units as shown in the picture.
I successfully fixed one of the toilets by replacing the seal at the bottom of the flush unit.
But the second continues to run, despite:
The offending toilet I dismantled and reassembled a year ago as part of a wetroom installation. Perhaps it's something to do with the screws that hold the cistern to the bowl? When I did this work I felt confident that it was done correctly.
I'm out of ideas. Anyone got any suggestions?
Silent Running Toilet eluding capture to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
- Replacing the seal at the base of the flush unit
- Swapping out the flush unit with the third (always ok) toilet
- Swapping out the flush unit holder that screws into the base of the cistern
- Tightening the screws that hold the cistern onto the bowl as much as possible.
