Hello friends. My 6RA7078 Type Simoreg driver to the machine
It sends an error "Continuous loop without Static Activation".
The fault I mentioned above is the failure of the machine, not the driver, but the reason for the alarm is the driver.
The signal it receives or sends from the PLC data block in the form of Simoreg_Temp_Stat ...
The A031 error occasionally occurs on my drive, but my machine keeps giving the error I mentioned above.
PLC Program shows that it is driver sourced.
However, if the fault gives 100 times, the driver gives the A031 fault only once.
So the problem may not be related to the A031 fault only.
Has anyone experienced or experienced this malfunction before?
How can I solve the problem if the static activation is related to the driver or the driver.
Thank you.
Thank you.
