1st off if it was a simple alarm problem i would have ot sorted and it would no longer be a problem!! Here we go...was sent today to install a simple alarm to alert a shop whem its back doors are opened. 2 rear doors. Both fitted with door contacts. 1 transformer. 1 small control panel with simple key on and off. A sounder is placed in shop.
basically have got power to panel but thats about it. Have wired everything in as i believe is corect, obviously wrong otherwise it would be working. I have tried adding a photo of the panel which hopefully will help. Iv tried to explain as much as i can before all the u useless £&!?£'ard comments. Did try the alarm section but is locked to me.
thanks in advance for any useful help n advice
cant seem to upload photo
iv taken power to the panel, then a cable from each contact back to panel then 1 cable to sounder. Which terminals would i connect sounder to on panel? And panel has 2 alarm terminals a and b. Somebody has told me to put both cables from contacts into same alarm a terminals. Does that sound right?
appologies again. If i could get a photo on it might help alot more. Picture paints a thousand words an all that!!
thanks again. Sorry about the essay!
