simple FCU question- turning off | on ElectriciansForums
Discuss simple FCU question- turning off in the UK Electrical Forum area at ElectriciansForums.net
haymarket
A simple question with hopefully a simple answer!
We have a switched 13A fcu which controls an external RCD protected double socket.
I can leave this on constantly and without anything plugged, it turns half off so the switch is level. I can turn it back on and it works fine
What could be causing this?
Thanks all.
[ElectriciansForums.net] simple FCU question- turning off
Thread gone a little off topic as usual.
I think the switch on your FCU is faulty. Replace safely if you feel confident doing so. If not, a friendly local electrician is required. 10 minute job
Reply to simple FCU question- turning off in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the advice.
Which rcd is it? Is it one for everything, one for a few circuits?
