Simple Question - 6 Fluorescent lights on 1 switch | on ElectriciansForums
Discuss Simple Question - 6 Fluorescent lights on 1 switch in the UK Electrical Forum area at ElectriciansForums.net
SKY
Hi All
Got to wire up 6 fluorescent lights over the next few days to 1 switch.
Is the easiest way as follows.
Feed from CU to switch
Feed from switch to lamp 1 then daisy chain from light 1 - 2, 2-3, 3-4, 4-5, 5-6?
Many Thanks
Simon
Why would you not go to the switch with the neutral i am currently at colege and they teached us how to take the neutral to the switch saying it is perfectly safe aslong as it does not exceed the switch rating you can get a lot of good switchs now that have a connection for the neutral at the back of the swtch. So i would take it to the swich as long as the florecent lights are the end of the line
Reply to Simple Question - 6 Fluorescent lights on 1 switch in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
