Simple Question caravan Parks | on ElectriciansForums
Discuss Simple Question caravan Parks in the Australia area at ElectriciansForums.net
M
monkee
If you had to design a caravan park from scratch would you wire all pitches as radial circuits or would you do a ring and run say six off a loop
pros and cons me thinks single supply to each one any thoughts please.
On larger installs I'm a fan of the ring main set up personally.
There are many factors to consider here though, as a spark I'm sure you are aware of them and will install a system accordingly.
A ring is the better option, you can probably get away using smaller cables than with radials. But all of course, Depends on many factors, that we can't comment on because you haven't given any information!!
Hi Lenny and others cheers for your thoughts
I have two customers who have a ring network and spurs of the ring feeding two or three caravans these were done in the seventies with large cables and lots of under ground joints no idea of costs with large incomers RCD protection
some sites are all just singles feeds up to 600 in one area my mind is ticking.
I have a customer who has a few sites and needs some work replacing old cables thay were asking on my thoughts
i have surgested thay look to a design company so that all the Tees are crossed etc.. ect... any thoughts
Reply to Simple Question caravan Parks in the Australia area at ElectriciansForums.net
