I am looking for guidance on adding a second pump for the underfloor section of my central heating. I am using a blending valve for the UFH supply by teeing off the main boiler feed into the 3 way valve and then to the pump and UF circuit valves (2).
I am ok with the wiring I simply need a relay to switch the UFH pump (and boiler) using the orange switched live from the valve via room programmer to avoid both pumps running when the UF only is required.
I need a 240v relay with say 10 amp capacity. I will put in an enclosure (I need one for each valve on the UFH circuits) so spade connections. I am having trouble finding something suitable in Farnell etc. Anyone know what I need and where to source please?
The boiler is a simple rocket oil fired boiler so no PCB controls.
Cheers
Cheers
