Simple screw up, need advice on wiring | on ElectriciansForums
Discuss Simple screw up, need advice on wiring in the UK Electrical Forum area at ElectriciansForums.net
Rina120
Pa
Hi folks!
new to the posting forum but was a lurker. I am hoping mind is simple and just not simple to me.
i have a solarium. Outside we’re 2 motion detector lights that didn’t work. One on the side, one on the front.
Inside the solarium are floor outlets. They used to work.
but, when I decided to replace the motion sensors, nothing works now.
there are only 2 wires that were in both Motion light boxes. One white, one blue.
currently, they are both capped off. Now I have no motion lights and no floor outlets.
what did I do wrong??
can anyone help? Electricians won’t come out in my neighborhood for something so small... hence DIY.
any help appreciated. I have multimeters, etc .
Hi folks!
Rina it sounds to me like you didn’t hook up your black or white correctly. Inside the motion sensor yes there is a blue for the hot black and white is your neutral. Did you have to take the whole light down to change the motion sensors.
Reply to Simple screw up, need advice on wiring in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
