I
icor1031
I am moving soon, but I will have a shed that I need to power, so I can use my wood work tools.
It's a rental, so I don't want to make permanent changes to the wiring.
The best power source I have access to is a 220v (USA, if it matters.) dryer outlet. It's on a 30amp breaker, and so far as I understand - the dryer outlets are also always rated for at least 30 amps.
Because I have 110v and 220v tools to power, this is what I want to do:
Run an 8/4 SOOW wire (as an extension cable, so as to not add any permanent wiring to the rental.) from that outlet, to my shed.
Split it 3 ways in the shed: I'll create two strings of 110v, by taking a single hot wire to each from the 220v. That will give me 60 amps (30 on each side) of 110v.
Last, I'll use both hot wires to create another 220v outlet for my 220v tool. That's 3 strings, and of course - when my 220v tool is running, I have fewer amps to give to the 110v lines.
Concerning outlets: My understanding is that I'm fine to use a 30 amp breaker on 15 amp outlets, so long as I don't draw more than 15 amps on that outlet.. The pass-through rating should be higher than 15 amps(?), but will it be enough for 30 amps?
Please be gentle, I'm a noob - and I know it :heart:.
I've heard conflicting answers whether it's okay to use both 110s on the 220. One person says the neutral wire will be running the sum (30+30 = 60, and therefore the neutral will get too hot.)..
Another person said that the neutral will only see the difference (if one 110v is @ 10amps, and the other is @ 5amps, the neutral sees 5 amps.)
What do you say, gentlemen?
