morning all, looking for some white, square corned single gang spacer rings / extensions 10mm, been to fit under floor heating thermostats but need 35mm back boxes, all house done in 25mm. think mk used to do them when everyone went mad for dimmer switchers on 16mm back boxes. local ce### wholesaler no help at moment. any ideas.
i mean .. cut around back box to release from plaster so that pulling the box out won't make a mess. a fein/bosch multitool is ideal for this.
If it's a new build, where you shouldn't be looking for ways around things and all the accessories should look the same (ie all flush mount) I know what I'd do.
Notts / yorkshire
United Kingdom
single back box extensions
Simon-0116,
Adam W,
