Single one way dimmer | on ElectriciansForums
Discuss Single one way dimmer in the DIY Electrical Advice area at ElectriciansForums.net
GX
Am replacing a faulty dimmer. Have put live in C, the blue in L1 and earthed green - doesnt work. It looks like my old dimmer had live and blue in L1 and L2 but I should have taken a picture. Is that even possible? I can try that of course or is it more likely that the connection wire isnt in firmly enough or even a faulty dimmer (is brand new). Thanks for any help.
Can you show the new dimmer connections and the wiring.
Reply to Single one way dimmer in the DIY Electrical Advice area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
