single or double pole sockets | on ElectriciansForums
Discuss single or double pole sockets in the UK Electrical Forum area at ElectriciansForums.net
F
foghorn
is there a requrement to install double pole sockets as to single pole sockets
OK, you may save 50p per point - so is it worth it or are you fitting 50+ - which would only be £25.00
And if you have problems later with RCD's you'll have to unplug everything too.
The Regs should be pushing for DP switches IMHO.
Reply to single or double pole sockets in the UK Electrical Forum area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
