single phase cap start / run motor wiring | on ElectriciansForums
Discuss single phase cap start / run motor wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
it all depends on which way you connect the L-N supply. either way round makes no odds. it's a.c.
Ok, well here's the problem.. I connected live to u1 and neutral to z2, fired it up and it ran fine. Was there with it running for about 20 mins then left to go to another job.
Got a call an hour later to say it was smoking do I went back and got a look. I checked caps and connections and all seemed fine although motor was really hot and the plastic connection box had melted. I fired it back up and it ran,.. but it ran like a dog. Sounded like it was sticking more than anything else.... And no smoke.
We phoned the supplier who said live and neutral where the wrong way about, so I reversed them and turned it on and it then started smoking and popped the mcb... (Had not popped the mcb until this point)...
Just wondering if I've actually wrecked this motor or if it's a duff one... ?
pete's post makes sense. connecting L and N arse about face would make no difference whatsoever to the motor. only othe thing i've seen is where the thing was plugged into a long, cheap extension lead and volt drop caused it to stall and burn out.
Cheers guys I was starting to doubt my sanity and have been checking countless wiring diagrams online.. centrifugal switch not disconnecting does make the most sense.. Was just concerned I'd damaged it
My suggestions in order of likelihood, assuming it's not mechanically overloaded or for wrong voltage / frequency (what's it driving?):
Cap faulty
Centrifugal switch didn't trip
Winding faulty
Caps connected wrong way
As above, nothing to do with supply polarity, makes no difference. One fault can lead to another. Mechanical overload can prevent it reaching speed, so the switch doesn't open, so the start cap fails, burning out the winding.
If the motor and fan were supplied as a unit you wouldn't expect an overload scenario, although FWIW propeller fans can absorb a surprising amount of power.
Sounds like faulty cap or winding, send it back...
Reply to single phase cap start / run motor wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Maybe look at replacing it with a VFD rather than a plain soft start...
Have you got the lid of the connection box on the motor? Often there's a wiring diagram inside the lid. What is the make and model number of the...
