B
blacklight186
Dear All,
Our company has a single phase induction motor Baldor make model VL5023A. It's a 1HP, 1725RPM, 1Ph, 60 Hz, 115/230 VAC single phase motor. More info can be found here https://www.baldorvip.com/servlet/productInfoPacket/VL5023A.pdf The last page of the pdf has the wiring diagram. LOW & HIGH refers to wiring for 115 & 230 VAC. STD & OPP refers to the directions of rotation (forward & reverse).
Due to the nature of our power supply in Dubai, we are forced to supply it 120 VAC, 50 Hz. Our end client in Saudi has 120 VAC 60 Hz. Anyway,for testing purposes in Dubai, we found that wiring it to LOW STD config (to accept 115VAC) caused it to draw a large amount of current (15.5 amps) along with heat & noise on no load. Wiring it to HIGH STD config (to accept 230 VAC) but still giving it only 120VAC caused it to draw a very minimal current of 2.3 Amps on no load.
I contact the Baldor motor company and their Sales rep. said that the overheating we faced was due to mismatch of the Hertz - at high torque, the starting winding was not getting disconnected from the circuit as it should, since the centrifugal switch was not opening (due to the hertz being less). This was causing the starting winding to remain in the circuit even when the high torque was reached.
But they could not explain why wiring it for 230 VAC but supplying it only 120 VAC (50 Hz) solved the problems. Please could someone help us with this?
Thanks,
blacklight186
Thanks,
blacklight186
