Single phase installation off a three phase cutout and distributors fuse details?? | on ElectriciansForums
Discuss Single phase installation off a three phase cutout and distributors fuse details?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Guest112
Hi guys,
Just finished a job installing communal lighting and power in 7 blocks of flats,
The supply for each building is the same a TNS 3 phase cutout with a feed jumped off one of the phases to the meter and from the meter supplying our single phase CU, the flats are then jumped off various phases but that's nothing to do with us we only came from the meter to supply our new CU
sooooo on page 2 in the supply characteristics in the first colum I have ticked the TNS option
then the number and type of wiring conductors I have ticked 3 phase 4 wire
then the nature of supply parameters iI have entered 400 and 230 as nominal voltages 50Hz frequency then my Ka and Ze obtained and then 1 source entered
then the characteristics of primary supply overcurrent protective device I have entered U through all the boxes as I can not determine the size and type of protective device and there isn't any information displayed on the fuse carriers,
Is this correct? my boss sent me up to check the cutouts for more information but I am not authorised to pull the distributors fuses to check so surely a U for Undetermined is satisfactory for the NIC forms??
any help would be greatly appreciated
Re: Single phase installation off a three phase cutout and distributors fuse details?
The nominal voltage to earth Uo will be 230V in all cases. It would only be 400V for phase to phase voltage, U, but I think NICIEC do put both on there.
If there is no information given on the DNO service head for the size of fuse then I would normally write N/V (not verified), but unconfirmed I suppose if that is what NICEIC want. Then this would sound to be all you can do unless you want to follow timbobelfast's advice, which is the approved answer, but may take more time than you expect to be unable to get a response!
Can you not obtain through enquiry to the DNO??
That was the suggestion I was going to put forward to my boss but surely U is an acceptable practice on the forms as this is a very common problem with testing???
cheers mate, yes I'm going to suggest to my boss regarding contacting the DNO but for now I have filled in the sections with a U and he can do what he wants regarding obtaining the information, perhaps he will speak to the customer and see if they would need the information or not?
Reply to Single phase installation off a three phase cutout and distributors fuse details?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
