Looking for some help with motor fault finding.
I've got a small woodworking router that i broke a couple of years back, given that we've just been covering very basic motor theory at college i want to see if i can either fix it or at least understand what's wrong with it if its terminal!
This is the router.
When i stripped it down i could see visible damage to the rotor windings and also marks on the housing where the windings have touched it. This has resulted in two individual strands being broken.
Im not sure if this is enough to write the armature off or not?
After a bit of googling and watching some youtube vids the tests i could find to carry out were to check the resistance at the two field windings (4.27ohms and 4.22ohm so i think they are ok) and to check the resistances across the opposite bars on the rotor.
There are 24 bars on the rotor shaft and they all but one read around 24ohms when testing the two bars 180degrees apart on the rotor, the last bar has no continuity to any of the others but as expected has continuity to one of the broken wires on the rotor winding. There is no continuity between any of the bars and the rotor shaft itself.
The carbon brushes need replacing as one wont touch the armature as its only half the size of the other brush, not sure if this indicates a fault or not? there is also some burning on that brush housing..
The bearings are fine and i think the physical damage to the windings has happened as i was pushing the router hard on a job it was nowhere near big enough for possibly distorting the housing a little.
I can pick some brushes up monday morning if this can be repaired, the router has been discontinued and you cant buy a replacement armature anymore so if its that i'll just scrap it!
Stu
This is the router.
Stu
