Single phase spur from Three phase isolator. | on ElectriciansForums
Discuss Single phase spur from Three phase isolator. in the UK Electrical Forum area at ElectriciansForums.net
Bedfordshire
Morning all,
Little advice regarding whether spuring from a Three phase isolator to a single phase FCU is allowed?
I need to wire a Single phase FCU which is located right next to a 16A TP isolator to a high speed door. Obviously, It would be a lot less pain to wire straight from the TP isolator to a SP FCU. Rather than running a cable from the Sub main for the FCU.
Anyone have any objections? I know it's not ideal. However, via a regulations point of view I can't find anything against this practice.
Cheers.
the TP circuit will have been designed for the size of load across the 3 phases for that piece of equipment....
to then add a SP load off one of the phases at that point may overload that one line out of the three.
TP circuit is fed from a C16 MCB with the FLC of the high speed door at 6A/phase. The SP FCU will power a security roller door which has a FLC of 6.5A. Realistically both doors cannot be used at the same time as the security roller door must be opened first before the high speed door will operate.
Hope that makes sense.
Think about it this way: if you had a 3Ph supply running to a small 3Ph DB which had a 3P MCB in it feeding an occasional device and the DB had 3 x 1P slots available, would you be posting the question?
Funnily enough I was on a job the other day where they had 2 roller shutter doors (3ph) on the same 10A supply, one effectively 'spurred' off the other.
Circuit cabling 2.5 so never going to be overloaded and whilst not sure of the flc, overloading of the mcb wasn't an issue the mcb had not been reported as tripping (it wasn't what I was on site for).
So no not ideal but no objections, its just another radial circuit!
Reply to Single phase spur from Three phase isolator. in the UK Electrical Forum area at ElectriciansForums.net
Agree with Dave disconnect unused Phases on the outgoing side of the isolator. No reason to replace mcbs with single pole, unless you need room...
Ok Dave thanks, no more accidents yet 🙏😂….
    • Informative
    • Winner
Do you recon this is three phase in? And any idea what the beasty grey metal box is?
I would personally leave it, a Ryfield or MEM Exel replacement would be consideral expense plus a replacement would/may require additional rcd...
I'm very similar mentally. When faced with a tricky fault I usually break out the crayons, it helps to visualise problems.
