Single phase supply from a 3 phase meter question | on ElectriciansForums
Discuss Single phase supply from a 3 phase meter question in the UK Electrical Forum area at ElectriciansForums.net
jedisparks
Hello,
Just wondered if I could pick some brains please. This might seem like a basic question to some but I am wondering there would be any problem with using just one phase from a 3 phase check meter?
I'm doing some work in a warehouse which is being divided into 2 units. one unit will be fed from an existing single phase board. The landlord wants a separate check meter for the other unit. There is actually a disused 3 phase check meter there, the load side from this is terminated into a 3 phase switch fuse with no DB or anything coming off it. So, essentially from an old 3 phase installation no longer used.
I'd like to simply take a single phase supply from the 3 phase switch fuse to run a small single phase supply in the new unit. Will only taking a single phase supply though the 3 phase check meter adversely affect the meter operation at all?
Hope that makes sense
Many thanks in advance.
Thanks for replying Howard. Apologies, I didn't make that clear. When I say check meter I mean a 3 phase meter installed on the consumers side of the installation, to enable the energy consumption of part of an installation to be monitored separately from another. The reading from this meter is then subtracted from the suppliers meter to separate the energy costs.
The link MDJ has provided shows the sort of meter I mean, it's an analogue meter. I want to know if taking just a single phase supply through one of these 3 phase meters will adversely affect it's operation. I can't see why but hoped someone more knowledgeable than me on this might know.
Many thanks
Reply to Single phase supply from a 3 phase meter question in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
I agree, it is a bit unfair when they change the rules. however, as a nation out usage patterns are changing and the most cost effective tariffs...
